Re: starting and staying trouble
Posted by Janicholson on February 03, 2011 at 11:45:45 from (199.17.6.165):
In Reply to: Re: starting and staying trouble posted by cary brief on February 03, 2011 at 11:38:28:
If you found voltage at the magneto (and your sure it is a magneto) and the tractor is not running, there is a problem. Disconnect the wire going to the side of the ""magneto""
there should only be a grounding to stop wire connected to that terminal. Any voltage there is bad news. Look at magnetos on Google to see what they look like, compared to point and coil based Distributor systems (which should have voltage to them from the ignition switch. If your battery is good, your starter is not. Jim
