Re: How much does it cost to rebuild a hydro transmission?
Posted by dieselbob on February 03, 2011 at 16:30:02 from (64.72.185.12):
In Reply to: How much does it cost to rebuild a hydro transmission? posted by like a deere but better on February 03, 2011 at 08:56:31:
Yes you can do a hydro yourself but first you need to do a little home work. Does the tractor slip under load or not move at all? By blowen do you mean there is metal in the oil. there are several checks that you need to do before a tear down. These trans are kinda fun to work on and very rebuildable in you own shop. I get my parts at a hyd shop, you can lap the rotating group at your shop, I have takes a lot of time. The only bad thing on the 656,666,hdro 70 is if the charge pump is bad then it hurts$$. Most important be clean. Any ??? drop me line. Good luck Bob
