Re: IH #52 Loader
Posted by scott mcintosh on February 03, 2011 at 17:01:53 from (216.180.204.93):
In Reply to: IH #52 Loader posted by JMP on February 03, 2011 at 13:31:08:
I have a 52 loader on a 400 I purchased in 1986 good loader but you are missing the braces that go to the rear axle,keep lots of iron on the back as she reaches out there along ways.I load spreaders over the cow yard fence.Keep good steering on her as you will need it.I have only come across one other 52 loader since 1986 and that was on a 656.If you ever need seals for cylinders give me a holler I have up to date part numbers as most dealers will not know what you are talking about.By the way mine says Mccormick No 52 underneath the old paint.Scott
