Posted by Janicholson on February 03, 2011 at 19:15:16 from (67.72.98.45):
In Reply to: 1949 MD Sleeve Failure posted by Sleeve Failure on February 03, 2011 at 19:06:03:
Best Guess on my way of thinking is thatthe sleeve was loose in the bore (too loose) and cracked around the top ring allowing the sleeve to drop down. as it dropped the top ring expanded above it and made a snap ring effect pulling it down into the crank case. Engines hate that, and puke sleeve fragments till they stop. It should not be a tough repair. Use service manual information on the sleeve fit. If you find the other sleeves are just fine, and want a single sleeve, LA Sleeve (on line) has them, or can make them easily. Jim
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
