With the tractor in low range, step on the foot-n-inch pedal (where the clutch would be if it was a gear drive), move the hydro lever into the blue area of quadrant, half throttle or so, hold the brakes, and let out the f-n-I pedal. A good hydro will overpower the brakes. In high range, same procedure, it should stall the engine. If the hydro starts whining instead of moving, the hydro has a problem.
you can get the hyd oil warmed up some, by putting the hi-lo lever in neutral and pushing the hydro lever up about halfway, before you test the hydro. i screwed up on a 186 hydro one time by trying it when the oil was stone cold. seemed ok but it wasn't.
for $2800, i'd be tempted to take a chance, unless there is a major problem like worn out tires. i had the hydro on my 826 rebuilt at hoober's for $2300, plus i split the tractor and put it back together. i didn't think that was too bad for a new hydro. you may not even need to do that much.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
