Hytran or an equivalent is what you'd use in the liftall pump now. They used engine oil because that's all there was in the 1940's. Hytran did not come along until around 1960.
Is this the engine oil pump, or the liftall pump? If you're working on the liftall pump, the gears tend to wear into the cover, causing a loss of pressure. Somewhere there's a technique for using a piece of glass and sandpaper to true up the surface of the cover, which brings the hydraulic pressure back. Since it's apart, you may as well take care of that issue.
For the engine pan gasket, sealant is up to you. Just don't glob it on there. A light smear, just enough to stick the gasket in place, is all you should need.
Be careful tightening the pan bolts, because you can actually bend the pan lip enough to cause leaks around the gasket.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
