Re: Oil leak around filter bolt head
Posted by rustyfarmall on February 04, 2011 at 08:00:55 from (209.152.78.140):
In Reply to: Oil leak around filter bolt head posted by Jessup on February 04, 2011 at 07:45:40:
You might need a different canister. I had that same thing happening on a 1940 H, and found that someone before me had been over-tightening that bolt and had actually distorted and worn down the hole where the bolt goes through. A different canister in GOOD shape solved the leakage problem.
