Re: Farmall H gas tank coating
Posted by Harold Evans on February 04, 2011 at 20:52:44 from (69.136.4.122):
In Reply to: Farmall H gas tank coating posted by bmagee on February 04, 2011 at 19:33:09:
I've used Red Kote on three of my tractors' gas tanks and it
worked great in all instances. You must clean the tank
thoroughly before application and then follow the directions
carefully. Don't rush the drying time because the longer it
sets up the harder will be the surface of your 'new' tank.
Good luck and please let us know what you think of this
stuff after you've tried it. I'm sure other brands of plastic
coatings would be equally effective. Just be sure to use the
proper chemicals to clean your tank as indicated on the
individual instructions.
