Re: gasoline powered 7.3 Power Stroke
Posted by DK44H on February 05, 2011 at 18:10:55 from (66.196.54.179):
In Reply to: Re: gasoline powered 7.3 Power Stroke posted by L.Williams on February 05, 2011 at 17:36:13:
I believe most diesels run in the neighborhood of 18 to 1 compression, not 30 to 1. You need at least 15 to 1 to burn diesel at all. The highest compression diesel out there is the old 6.5s, running about 21 to 1. Thats why thhose 6.5s could only handle about 10psi of boost before blowing the head clean off (mine hits 12psi regularly). However the newer diesels can run 2 to 3 times more boost because of the lower compression ratios. Chevy tried to build power with compression and everyone else went with less comp and more boost. They won.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
