Re: Lift-All Seal
Posted by sflem849 on February 05, 2011 at 18:15:34 from (69.197.84.192):
In Reply to: Lift-All Seal posted by Bubba Racing on February 05, 2011 at 17:20:02:
No need to split the tractor. You do need (at least it is easiest, I'm not positive it is a must) to drop the "Lift-All" pump. To do this just get a buddy and put a jack under it. Put a slight pressure on it with the jack and undo the four bolts and pipes etc. "Removal steps should be apparent" I'm sorry, too much of the worthless I&T manual today. You will need the jack to help you lower it bc it is fairly heavy. One guy runs the jack while the other guy holds the pump steady. Others have used four hunks of all thread if they are by themselves.
