Technically you are putting surge current onto the tractor ground when welding. Not as much as a lightning strike however. I don't know how much surge there would be but to complete a circuit, it would have to go through the battery if connected and then through the fuses and key switch and other on switches. What's welding current? Maybe 28 volts at 125 amps?
If all your switches are turned off, then any surge current shouldn't get into any electronics. If the battery is connected, I suppose some surge current could go through it and to the starter solenoid.
Due to the resistance of the steel frame, I suppose it would make a difference as to how far you are welding from the electronics as everything would have a common ground to the frame. Welding around the loader would be a lot different than welding around the dash where the electronics are. How long you weld would make a difference as well.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
