Re: f12 powerlift question
Posted by F14 on July 13, 2000 at 13:42:44 from (216.252.28.27):
In Reply to: f12 powerlift question posted by greg m on July 13, 2000 at 05:47:55:
The F-12/14 power lift is a pretty straight forward operation. The pump is on the left side as viewed from the seat, and is a simple two-gear pump driven off the transmission, running any time the clutch is out. There is a cast manifold between the pump and the lift mechanism, with supply and return runs separate in one casting. The valve fits on the front of the lift housing, and has two positions: All the way up or all the way down. The lift itself consists of the lift housing, the lift arm or rotor, and a spring-loaded vane in the lift cylinder. As the lift vane reaches one end or the other of it's travel, it uncovers a bypass hole that lets the pump circulate oil at all times. It uses regular gear oil. I use 80/90 in mine. There are really only a couple of things that will cause it not to work at all: No oil in the system, or the pump not turning. The pump shaft does have a seal on it that will allow oil from the powerlift to drain into the transmission if it goes out, and there are seals on the lift shafts that will let oil seep out. If the oil is just low, the lift should at least move, but may not travel the full distance. Also, there is a spring loaded pressure relief on the bottom of the pump. It's about 6" long and looks like a piece of pipe with a cap on it. First thing I'd do is pull the pipe plug on the top of the lift housing and make sure there's oil in it. Second thing would be to make sure the pump is turning. You can pull the outer cover off it (after draining the oil) and then start the tractor and check that the pump gears are turning. I can't think of an easier way to check it. Good luck, and let us know how things come out.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
