Posted by jdemaris on February 06, 2011 at 06:24:05 from (67.142.130.14):
In Reply to: Re: b250 fuel punp posted by MJ in the UK on February 06, 2011 at 04:59:07:
Yeah I know the B250s with the BD144s differ a bit from the BD144s in the B275s. I have B275s, B414s and a 3414. I've never bought a B250 since it lacks the hi-low range trans.
I still have my new primer-pump sitting in a box. I had it installed for a few months, but then decided to intall an electric pump instead. I did that because I built a block-off plate to install in the injection pump instead of the primer-pump - with an easy oil-fill port. The old CAV inline leaks a lot of diesel fuel into it's cam-box, so this makes it easy to drain and fill with oil often.
Some day I'll fix it right. I suspect it needs new pump plungers and barrels. I found a place in England that has all the new parts. $200 for a set of four plungers, barrels, and delivery valves.
How well does your B250 start in the cold? I'm curioius since with mine - all mine with in-line pumps start terrible. All the later ones with CAV rotary pumps start great. Even with fast-heat Mercededs glow plugs, the old ones are still miserable starters in the cold. Run great though, once warmed up.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
