if you do what i said with a log and send it up and she just sags down again, then you wann isolate your piston/ram/cylinder. jack up the rear with a floorjack then lower the fasthitch to a log, then disconnect the 2 lines going to your cylinder and put some brass plugs in(you can get at any auto parts store) then lower your floor jack till the weight of the tractor is on the fast hitch with the rear wheels still off the ground, remove floor jack and see if she sags then, if it does your cyl is leaking if she holds you might wann look at you control vavle the leakby could be in there and that might need rebuiling...
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
