Re: M farmall
Posted by Dan Bear Kelley on February 06, 2011 at 07:49:36 from (206.53.20.96):
In Reply to: M farmall posted by rick deere on February 06, 2011 at 06:04:49:
Remember, these babies could be hand cranked to start. So, starter speed is not really an issue. If you get one cylinder to pop, it can start the whole beast. Generally, only two things will prevent a gasoline engine from starting: Lack of gas or lack of spark. Verify both of those systems and stop messing with the starting system. If you really feel that compression is low and you need a faster starter, check your valve lash. When I first got my M, my valve lash was so far out, it was a wonder the engine was running at all.
