Posted by kevinj54 on February 06, 2011 at 12:44:55 from (71.115.142.178):
In Reply to: M farmall posted by D Slater on February 06, 2011 at 06:04:49:
rick deere said: (quoted from post at 16:28:25 02/06/11) Has a new 1000 cranking amp 12 volt battery, engine will not turn fast enough to start...turn key on and push button on floor or in front of gear shift. can I be loosing my fire threw distributor???starter was looked at by the pros
You did not say it was on 12 volts.
Distributor has NO bearing on cranking speed
So a step down starter is just a stock M starter after all???
That should really spin.
IF the starter is good then you have cable & connection issues.
You need to take some volt readings while cranking the engine and some amp draws on the starter.
This post was edited by kevinj54 at 12:47:07 02/06/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
