Posted by Faster346 on February 06, 2011 at 13:38:33 from (72.241.213.69):
In Reply to: 6 volts to 12 volts posted by jojo1 on February 06, 2011 at 13:22:09:
Here's a wiring diagram for 12v conversion with a Delco 10SI 3 wire.
Basically:
12v battery
2gauge Positive & Negative cables
Switch to NEGATIVE GROUND
Fabricate some sort of bracket to hold a small alternator, most use a GM Delco 10si which is small and common/cheap and will fit under your hood
Switch the coil wires around for your new polarity. You want the - side of the coil to go to the distributor, and the + side going to the kill switch
Wire in a 1.82 OHM resistor between the positive wire of the dist and the ign switch (Napa ICR13 ballast resistor works well) or swap to a 12v Coil (NAPA IC14 works well)
You will want to switch your Ammeter gauge wires around so it doesn't read backwards
This post was edited by Faster346 at 13:42:41 02/06/11 4 times.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
