Re: 300U Fast Hitch Down pressure
Posted by mike paulson on February 06, 2011 at 15:12:23 from (98.15.178.36):
In Reply to: 300U Fast Hitch Down pressure posted by Dellbertt on February 06, 2011 at 05:28:40:
hey Dell, try it with the lines disconnected and plugged, by doing this you will be isolating the cylinder taking the control valve out of the picture...in other words the cyl wont be able to move fluid down either line because they are sealed with your plugs, so if the fast hitch goes down/sags then its because the fluid is passing inside the cylinder internally...
