Re: 300 Misfire when Cold
Posted by Tom Fleming on February 06, 2011 at 15:44:01 from (67.20.243.240):
In Reply to: 300 Misfire when Cold posted by Lee Jr. on February 05, 2011 at 16:19:20:
Either you are too rich, OR check your air cleaner. Make sure of 2 things: the bottom is clean and you are not using too heavy of oil. The manual says to use the same SAE oil in the cleaner as you do in the engine. so, in the old days, when it got cold enough to change the oil from SAE 30 to SAE 10 (or SAE20), that is what you used in the air cleaner also.
Bottom line, sooty plugs is either too much fuel or not enough air (for the most part).
