Posted by pete 23 on February 06, 2011 at 17:16:31 from (173.87.15.134):
In Reply to: Farmall 656 Starter posted by Tom 8n396936 on February 06, 2011 at 14:19:45:
No doubt you have a bad drive , problem is like stated, figuring out which drive is correct for this tractor. It is not a bendix as it is a clutch type drive. If you put same number teeth drive back in and it is wrong you just bought a wrong drive and or starter complete which ever way you go. Like I said before, the service bulletin would tell you what count of teeth on ring gear goes with what count of teeth on starter drive gear. I have a 656 gasoline gear drive apart right now for clutch and ta job. I will count the teeth on flywheel and starter when I get back out there tomorrow weather etc permitting. I will note engine and tractor serial number. I may ask parts dept at CASEIH if they can furnish me a bulletin also as I have to call him for other things as well.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
