Posted by Janicholson on February 06, 2011 at 18:07:39 from (67.72.98.45):
In Reply to: 1466 IH posted by tractorhunter on February 06, 2011 at 14:54:53:
If the hydraulic fluid is at the full mark, put an extra 5 gallons in it. There is a good chance the Secondary Pump (steering and other stuff) is sucking air through a bad Oring or other loss of prime. The extra will not hurt anything, but may solve the issue. If this does not fix it, look towards bleeding the MCV valve (see Archives for details) The pump drive could be sheared if it was frozen and started. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
