Re: M farmall
Posted by farmallhal on February 06, 2011 at 19:34:35 from (76.2.177.91):
In Reply to: M farmall posted by rick deere on February 06, 2011 at 06:04:49:
Rick, have some new cables made up using 00 cable with soldered terminals and routed the shortest distance possible. Ground the battery to a starter to tractor frame mounting bolt. Clean all connections as clean as possible. Use external tooth washers between all cable terminals and whatever they contact for current flow as they bite into metalic parts for improved contact. That is about the best you can do except replace the switch which can lose efficiency as well. If that doesn't fix your problem you need to check each part, starter, battery, wiring, etc. to find the problem. Hope this helps, Hal.
