Re: SMTA Front Gas Tank Support
Posted by rustyfarmall on February 07, 2011 at 17:07:47 from (209.152.78.140):
In Reply to: SMTA Front Gas Tank Support posted by teddy52food on February 07, 2011 at 15:42:51:
No, there is a threaded insert welded into the tank. The threaded stud screws into that insert. You can completely remove the stud and the tank should not leak.
