Re: how to get ahold of wardner???
Posted by Wardner on February 07, 2011 at 17:47:49 from (209.86.226.40):
In Reply to: Re: how to get ahold of wardner??? posted by bornred on February 07, 2011 at 16:30:14:
Bornred,
Yes, I did put a 560 gearset in a SMTA. This was more than ten years ago and I can't remember the details. I know that either the IPTO or the mainshaft uses a different bearing at the partition between the transmission and differential.
I had a complete 560 rear frame and I was able to make do with what I had between both tractors. I know that I would have opted for the larger bearing if there had been a choice. I also think that it won't be necessary to use the wider bearing and matching retainer if you don't have them.
In situations like this, I always consult both parts books and look at all the affected parts. You can go to the CaseIH on-line parts book and do the research.
Lets assume that there is a different bearing and retainer on the rear of the mainshaft and you don't have the parts. In that case you could have a new snap-ring groove machined on the 560 mainshaft.
If you are also looking for a lower first gear, I think you will find the 560 first gear to be about 10% slower.
D Slater has all this interchange info burned into his brain. Perhaps he will respond.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
