Re: 6 volts to 12 volts
Posted by Dieselcowboy on February 07, 2011 at 17:53:55 from (99.130.204.45):
In Reply to: 6 volts to 12 volts posted by jojo1 on February 06, 2011 at 13:22:09:
I'm not real sure why everyone wastes their time putting an alt a 6 volt tractor. 1st it takes way too much though and work to mount and looks way out of place. I have 4 tractors converted to 12 volt by myself that still have the original gen and work perfectly even with aftermarket elec. acesseries. Here's your clue. A generator charges as much as it is told to. It WILL charge 6, 12, or 24 volts with no mods to the gen. its self.
