Re: 6 volts to 12 volts
Posted by Faster346 on February 07, 2011 at 18:39:16 from (72.241.213.69):
In Reply to: 6 volts to 12 volts posted by old on February 06, 2011 at 13:22:09:
So a 12v voltage regulator, napa 12v coil, and a 12v dumped in the box while still using negative ground is all you need? If it was that simple it seems like people would've been doing it for years. Something doesn't sound right, but I don't know?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
