Re: Farmall 230 quits after running fine for 30 min
Posted by wayne in mn on February 07, 2011 at 20:50:40 from (24.179.172.185):
In Reply to: Farmall 230 quits after running fine for 30 min posted by John McFadden on February 07, 2011 at 19:51:30:
When it quits next time immediately check for spark quality. Should be bright blue & "snappy" able to jump at least a ¼" gap. Poor or no spark = coil &/or condensor problems.
