Re: Farmall H Front Wheel Wobble
Posted by mkirsch on February 08, 2011 at 05:23:52 from (64.80.108.56):
In Reply to: Farmall H Front Wheel Wobble posted by George Rausch on February 08, 2011 at 05:06:58:
It's usually a combination of several wear points.
The gear fit on top of the shaft is usually a little loose. May need a beer can shim to tighten it up.
The gear teeth are a little loose. Not much you can do about this one unless you spend a LOT of money. New sector gears are close to $400 if you can find them, and the worm gear on the steering shaft is NLA.
Both bushings inside the steering post are definitely worn. You need to drop the vertical steering shaft out of the tractor, and replace those along with the seal that's in the bottom so it will hold oil.
Sometimes you can get them toned down to an acceptable level just by tightening the fit of the sector gear on the vertical steering shaft.
Running one tire a little soft is also a temporary fix.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
