I will contribute to the input with the dynamics of the intake/exhaust and cam design. The carburation flow volume at ~1800rpm is about all that the carb can handle and deliver fuel correctly. (with the engine producing its highest level of output, throttle wide open. It will make more torque and fill its cylinders fully at the 1650 point, due to cam timing, valve lift and intake runner size. The reality is that if the cam, and carburation, intake (from a 350 lets say) were used it could operate at a higher RPM making more power. Adding RPM only will make a faster tractor on the road, and in any gear while not pulling, but that only feels more powerful, and achieves little. Jim
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the
... [Read Article]
Latest Ad:
[More Ads]
