My memory needs refreshed on this, what I remember now is a serial # cut off on the F560 rear housings. First type used the same main shaft rear bearing retainer as a 400 ETC. Other type used 4 bolt retainer with a different transmission housing. Same main shaft works in both. Roller or ball bearing works in both retainers. F560 were equiped with a choice of 2 speeds for 1,3,4. Standard 1 is more gear reduction than a 400. 560 high speed 1&R is the same as standard 400. 560 3&4 standard is less gear reduction than a 400. Heavy tilage gears in a F560 are the same as standard 400 gears. Depending on tire size using 1450 RPM, speeds from around 1 MPH to near 8 MPH from gears 1 through 4 are posible. Just the F560 R&P slows a 400 down a bunch. At stock RPM 4th will be around a regular M speed. Top speed will be down. If backing a distance reverse speed reduction may be a problem. If 1st gear ratios are switched the reverse idler needs switched to match also.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
