Re: Does adjusting the governor on Farmall H=extra hp?
Posted by rich4 on February 08, 2011 at 09:38:52 from (74.60.110.90):
In Reply to: Does adjusting the governor on Farmall H=extra hp? posted by VII Gen. Farmer on February 07, 2011 at 21:29:19:
Large 4 cyl tractor engines more than 150ci and long stroke are not balanced for a lot of RPM , I know some 4 cyl perkins engines had a balancing shaft engineered in the block to smooth out the engine over 2000rpm. A couple hundred rpm more should not hurt, but if the engine runs rough then it is too much. The cam and carburator also a limiting factor.
