Re: IH Little Genius Plow Shares and Landsides
Posted by mkirsch on February 09, 2011 at 05:30:46 from (64.80.108.56):
In Reply to: IH Little Genius Plow Shares and Landsides posted by Jim R on February 08, 2011 at 14:07:40:
Nobody is currently producing replacement parts for the Little Genius plow bottoms.
Shares pop up on ebay from time to time, but there are so many different ones you need to make sure that you get the right one, or it won't fit. Plus they usually bring near $100 apiece, because people desperate for parts run the bid up.
The only IH plow bottom with parts currently in production is the Super Chief. You can get new parts at your local CaseIH dealer, Tractor Supply, Weise, and several other online sources.
What you need to do is keep your eye out for a newer IH plow with the Super Chief bottoms, buy it cheap, and transfer the bottoms to your Little Genius. They will bolt right on.
In the meantime, you can shore up the worn areas by welding on steel. Even a badly worn bottom will do a lot of plowing at an antique plow day... They usually don't plow very deep and you don't make very many rounds before the field is plowed.
