Did you check with the throttle wide open and have a non restricted air cleaner. may check the valve clearance and cam lift, but if all cylinders are the same pressure thats probably not the problem. One thing that may give you low power and low compression besides a internal engine problem, is the carburetor butterfly not opening completly. Due to a worn governer or throttle linkage system not correct.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
