Re: THE tank cleaning procedure per Red-Kote Chemist
Posted by Kendog on February 09, 2011 at 08:45:14 from (71.186.182.111):
In Reply to: THE tank cleaning procedure per Red-Kote Chemist posted by sflem849 on February 09, 2011 at 07:33:17:
IF, however your tank has a baffle inside as many Farmalls & other tanks have, dilute the RedKote 50/50 with MEK, and do two thin coats with about 1/2hr between coats. Otherwise you will get pooling in the corners which will not dry properly. You want to prevent 'skinning' inside that traps liquid material, and will later peal off or mix with gasoline, plugging your carb.
