Re: UD-16
Posted by M Diesel on February 09, 2011 at 14:18:47 from (12.24.61.12):
In Reply to: UD-16 posted by Harold H on February 09, 2011 at 06:13:06:
As said the UD16 (D502 actually) are a 9 engine (D335) with 2 more cylinders. It also means parts are still difficult.
At least it turns some. My "guess" is light rust in one cylinder. It might go thru, but may break rings doing it. I have got one to work loose by rocking it back and forth. And with proper application of some antiseize that old gasket will work again.
Figure on roughly 2500 lbs (+/-500) for an entire unit, depending on how it was configured and how much has been removed. $300 should be plenty, $200 is closer.
