The gear is coupled to the shaft with a woodruf key. There is a diameter change from what I can see (caseih.com search for parts) I believe it must come out the rear. A ball bearing, and a bushing are on the other side. The woodruf key is probably snagging in the hub of the gear. As far as welding it. That may be the only way to make what you have work at all. putting it in a lathe large enough to turn the shaft while letting the housing float, might allow the removal of the existing weld, forming a 3/8 deep X 3/wide groove at the point the shaft fits the gear hub. A good welder with 7018 or 100 series rod could make it work. No guarantees. (but there weren't guarantees on the original weld either. It probably had shrink cracks in it from just after it cooled. Good luck. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
