The shaft comes out the back, the side opposite the gear. There is a shoulder on the shaft that rests against the outside bearing inner race and won't let the shaft come out towart the gear side. There are two bearings on the shaft, one behind the oil seal on the outside and another on the inside behind the gear. If you want to get the shaft out, you will have to remove the weld to where you can get the gear off. The gear and woodruff key have to come off to get the shaft out. You can't drive the shaft out through the gear, as the woodruff key will hit the housing and prevent driving the shaft out. The gear is supposed to be retained on the shaft with a heavy washer and a bolt in the end of the shaft. I think I see part of a broken off bolt in the center of the weld in your photo. If I had your situation, I would try to find a complete PTO unit at a salvage yard and scrap the one you have now.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
