Posted by rustred on February 10, 2011 at 15:56:58 from (74.200.18.155):
In Reply to: M Carburetor? posted by FarmerBrawn on February 10, 2011 at 06:45:55:
did the carb get soaked in carb cleaner? was the valves adjusted hot to .017 in proper sequence as per firing order and rechecked now? you may have a thin margin on a valve and the seat has worn a groove in it and lost your valve clearance.may have a valve leaking. c ompression @ 100 psi, is that for all 4cyls.? results should be posted for all 4cyls. was the head profesionally rebuilt? guides not worn out? sometimes on paper need a 100 questions answered but when you have visual contact may be a quick diagnosis, as the problem can be spotted with experience and a trained eye.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
