Re: More IH 350 questions
Posted by berakel on February 11, 2011 at 08:12:36 from (173.27.158.108):
In Reply to: More IH 350 questions posted by Kenneth w on February 10, 2011 at 14:11:23:
touch control - if tractor has a fast hitch you would use the outside lever to raise or lower the hitch. the other one or two levers control remote hyd lift cylinders. the hyd control levers are to the right of the steering wheel above the brake pedals. push forward to raise, pull back to lower.
under the right side hood (there may be a hole on top of hood right side) on each hyd control valve is a 1" shaft sticking up on the top of the valve. it has flats for a 3/4" wrench to turn it about 1/4 turn for single acting (one hose) or double acting (two hoses) hyd cylinder operation.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
