Re: M Sputters Stalls When Throttled or Loaded Up
Posted by LaBoyteaux on February 11, 2011 at 09:22:33 from (76.14.94.14):
In Reply to: M Sputters Stalls When Throttled or Loaded Up posted by dieseldalec on February 11, 2011 at 08:40:23:
My M (and other tractors) do the same thing and the problem is usually a gas line obstruction. It gets enough gas to run at idle or no load but as soon as it needs more fuel it sputters and stalls. The most common obstructions are crud at the gas tank outlet or crud built up on the brass screen at the float bowl inlet.
Any in line fuel filters should also be cleaned or replaced.
For rusty carburators I usually clean the iron parts in a sand blast cabinet.
John
