Re: Gas in my oil.
Posted by rustred on February 11, 2011 at 11:31:56 from (74.200.18.155):
In Reply to: Gas in my oil. posted by jdp8402 on February 11, 2011 at 09:33:52:
anytime the oil is thinned out that is not good.your bringing the oil viscosity down and probably notice a drop in oil pressure as its running past the brgs. faster which creates more brg. wear. also can glaze the sleeves if the engine is not up to operating temp. you will notice this if your tractor starts using more oil than before. to cure this need to run it hot and give her a sniff of bon-amy in the intake at fast idle.
