Re: OT Hollow Out A Spark Plug
Posted by Roger46 on February 11, 2011 at 12:51:51 from (75.221.134.136):
In Reply to: OT Hollow Out A Spark Plug posted by Kendog on February 10, 2011 at 09:31:57:
I recently decided to put umbrella seals on my Farmall A since it was smoking a lot at idle. I took an old spark plug and knocked the center out, broke off the side electrode, and discovered that the ID of the plug shell was the exact size for a 1/4" pipe tap. I just ran the tap in, screwed a 1/4" pipe, and a quick disconnect. Then I screwed that into the head of my A and put air pressure on it to hold the valves closed while I took the keepers out of the valves to put in the seals. It worked real well. Roger
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
