Re: Gas in my oil.
Posted by old on February 11, 2011 at 12:55:12 from (4.245.10.231):
In Reply to: Gas in my oil. posted by jdp8402 on February 11, 2011 at 09:33:52:
Catch some of that oil I would use the lower check plug doing it. Be sure yo use a can of some sort. Take it off to the side and use a stick to see if it will burn easy. If it does light up easy and burn you need to change the oil and also check the carb out. It is always a good idea to shut the gas off when ever you park any tractor because gas in the oil is very bad and end up causing you to have to rebuild the engine
