Re: 400 cyclo no till
Posted by Moline_guy on February 11, 2011 at 13:46:58 from (216.106.217.128):
In Reply to: 400 cyclo no till posted by youngin on February 09, 2011 at 15:52:30:
The neighbor had a 400 with the yetter units, problem was the front hitch, rear part of the hitch where it mounts to the frame, and the cross frame needed to be reinforced because of the extra pull of the units. His was an 8row. Another neighbor eliminated the spring and put a solid stop on it so there was no give, he uses it to plant food plots and seems to work ok, my guess if you would hit a rock something is going to bend. 800 has good penetration and is a much heavier unit and are getting down right cheap in our area. Good luck with whatever you decide.
