Frame rails are the same length on M through 450 tractors. MD, SMD. SMTA and SMTAD all have a front bolster that when bolted to the frame rails, moves the point the front wheel bolster bolts on 1-1/2 inch longer from the rear of engine than M or SM gas tractors. Also radiator along with the grill is moved forward from rear of the engine the same amount. MD, SMD, SMTA, and SMTAD all use the same length steering worm shaft. You can bolt a M front bolster along with fan shrould, worm shaft and coolant pipe on a SMTA gas tractor and the M hood will fit.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
