Re: Do C's and Super C's use the same carb?
Posted by Lmack on February 11, 2011 at 18:30:02 from (72.145.199.165):
In Reply to: Do C's and Super C's use the same carb? posted by Faster346 on February 10, 2011 at 16:54:36:
If the tractor has been setting up for a while it is not out of the question that it will run rough for a while especially with the gasoline we get now. Ours always did for about the first fuel tank after a long rest. You may have to clean the fuel line, drain the carburetor, and clean the sediment bowl several times to get it to run just right. Try this before taring into the carb. It may be the old gasoline. Some of those fuel additives that dissolve the water may also help.
