Posted by Owen Aaland on February 11, 2011 at 18:56:18 from (63.167.132.13):
In Reply to: 706 gas posted by C. Meyer on February 11, 2011 at 11:08:06:
Drain the oil from the rear frame. Remove the bolts around the outside of the cover that is ahead of the left rear axle, directly across from the hydraulic filter. Remove the cover assembly. The pump is mounted to the cover assembly with the remaining four bolts.
