Re: No oil pressure.
Posted by Red John 2 on February 11, 2011 at 19:17:12 from (72.188.248.231):
In Reply to: Re: No oil pressure. posted by CNKS on February 11, 2011 at 18:01:59:
CNKS, Just as thought here.... are you sure the center bolt holding the rocker arms down to head is the correct HOLLOW bolt? This bolt provides the opening for the oil to get to the rocker arms.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
