Re: No oil pressure.
Posted by CNKS on February 11, 2011 at 19:55:34 from (216.144.104.128):
In Reply to: Re: No oil pressure. posted by gene bender on February 11, 2011 at 19:34:33:
My first step before starting it the first time was to remove the spark plugs and turn the engine over fast hoping to see oil at the rockers--nothing. I have not cranked the engine with the filter drain plug out, but I have removed the plug shortly after and gotten oil out, along with oil in the accessible passage that is a few inches up in the block. I will keep looking, not eager to disassemble the engine again. Will try the air in the hole to the rockers. Glad to hear there are no plugs in front.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
