Re: What to offer on an M, and what is that thing on it?
Posted by Tom Fleming on February 12, 2011 at 05:28:26 from (67.20.243.240):
In Reply to: What to offer on an M, and what is that thing on it? posted by Zachary Hoyt on February 12, 2011 at 03:57:55:
Are you looking to restore it, work it, or both? For a work tractor, mis-matched tires are not a crisis, if they will hold air. Tubes: $60-$75 each. Stuck engine, could be dry stuck, easy enough to free up. Bit of penetrating oil, and it is wasn't already wore out, it may run fine.
Tractor appears to be all there. neat design on the crane (or what appears to be crane).
You judge on your pocket book. If it were me, I would consider in the $600-$800 range. Top end would be $1000. I paid $1200 for a non-running SM in worse shape than that. I was happy to get it for that considering what SM's go for in my area (western Pa)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
